Fixing Intake Manifold Leak....any tips?
#36
the back end is where it usually leaks first. If you run your hand on the back of the intake you should come up with some oil if its leaking. It leaks down onto the transmission and oil pan, and drips onto the exhaust pipe...mine is also all over the starter as well.
#38
Guess what we do when we don't have a certain gasket? We make one. And cereal box works damn well.
Cereal box is not a gasket and using it the way you suggest is un-necessary and probably weakens the sealing of that joint significantly.
You usually can get Pertmatex "The Right Stuff" at Auto Zone. It isn't cheap.
#39
I have had a bunch of trouble with the GM grey stuff and will definitely be using something different next time.
BTW... I have also seen cereal box used for gasket material. It is an old mechanics trick. I have seen used for an intake gasket, but for water pumps, water inlets and fuel pumps and it worked great.
To do it you use a hammer and beat around the edge of whatever you are making a gasket for with a hammer with the material on top of it. Then you can easily tell where to cut it and thus make a pattern. Seems to work very well.
CARiD
01-27-2015 06:27 AM
07-04-2005 05:00 PM
