Flex plate bolts
Flex plate bolts
Does anyone know the GM part number for flex plate bolts or the ARP quivalent number. The dealership ordered me the wrong ones and swear thats the only part number shown. ARP does not have a seperate part number just for the LT1s. None of the performance parts website have flex plate bolts listed, just flywheel bolts
I've used the ARP 12-point flex plate bolts and didn't like them. The head on the ARPs is so large you can't get fit a socket between the rear hub and bolt heads. So, I bought replacement OEM bolts at the Chevy parts department. They didn't have any problem looking-up the part number.
Also, make sure you don't have a powder coated TCI flexplate and use some thread locker along with the proper torque.
WD
WD
WD
WD
WD
WD
Also I took the powder coat off the flexplate where the bolt heads were with a diegrinder and a 3M rolock disc... You should always do that on a flexplate.
WD
carguyshu
01-22-2017 11:19 AM
Richardan15
05-30-2015 08:36 AM
