Flush your reservoir
I never thought to ever flush out my coolant reservoir. I did it two days ago and all I have to say is:
So much MUD came out. Its actually mineral deposits from using tap water with coolant.
H2O evaporates. The minerals don't so they remain as a deposit. This is the same deposit which turns your coolant to mud. Literally.
Want to see how much crap is in your cooling system? Disconnect and remove your battery.
Next, disconnect the hose running from the reservoir under the battery to the back of the radiator cap.
Remove the two retaining bolts and pull the reservoir out. Dump it into a bath tub. Wash it out and watch how much mud comes out. That mud is circulating in your motor.
Noct
07-14-2015 01:18 AM
odium
11
06-24-2002 09:58 PM
