Flywheel Question
Flywheel Question
Alright so i'm building a 355 looking to put down about 390 to wheels. I'm replacing everything. So i need to know if a new OEM flywheel will last or if i need a performance one. Also probably gonna run a spec 3 or 3+ clutch.
Sure, the stock flywheel will work, but I sure wouldn't risk having a cast iron flywheel explode and remove my feet to save $300 If you're going to drive it hard, get a billet flywheel and and wrap the bell housing with a trans blanket.
