Fog Light Switch
Fog Light Switch
I have a question for someone.
When I flip on my fog light switch it blows the fuse, would this mean that the switch is bad or that the lights are? I have not dove into looking at it yet but was curious if anyone had this issue before. How do you even get the fog light switch off and out?
You have a short.
Most likely in the lamp.
You could take apart the connection at the light and test it with an ohmmeter.
You should measure some resistance - if it is registers as "closed" then it's the lamp.
Good Luck!
Good Luck!
