forged 355 running, still couple problems. (Part II)
#16
Re: forged 355 running, still couple problems. (Part II)
Originally Posted by blackztpi
bret, i adjusted them the way you stated. i can completely rock the rockers that are at TDC. i can pull the tip off the pushrud and off the valve. way too loose. ???
Why TDC? you need to make sure the cam is on the base circle before you check them.
Bret
#17
bringing the #1 clyinder to TDC allows me to adjust certain rockers. then #6 TDC lets me do the rest. the cam is supposed to be on it's base circle then i guess. do you have any other suggestions for adjustment? i can't do it when the car is running because i can't hear the ticking it's supposed to make when you loosen a rocker. i went back to the pushrod method and got it the quietest it's been, but it still sounds like noise from the passenger side a little. definately getting better though
