Freeze Plug for Timing chain cover?
I have an electric water pump on my 96 LT1 and I need to know what size freeze plug I can use to plug the whole with. I know some of you have done this....please let me know asap.
-Patrick
-Patrick
Re: Freeze Plug for Timing chain cover?
Originally Posted by simple
take it to the auto parts store you'll be able too test fit it while its still in the plastic
its either 1 1/16" or 1 1/8" i cant remember off hand
If I am not mistaken, it is a 32 mm. Go to napa, and they can hook you up. that is where I got mine when I did my electric water pump and double roller. It has been a while back, but I am fairly sure it was a 32mm. they are only like a dollar a piece, so it may not hurt to pick up a 30 and 34 just to be sure.
ill look for the freeze plug...but if not guess ill just have to go with the quarter and some JB weld since its working for alot of you guys. Thanks!
