freeze plugs
freeze plugs
i've just replaced the water pump on my camaro. unforunately it didn't solve the problem, i still have coolant leaking. this leak is coming from just behind the water pump, but not from the pump. i was wondering where the freeze plugs are located, as this may be my problem. i also wonder if it could be coming from gasket between the cover assembly and the block. please help me if you can. i'm not extremely car savy, but do what i can.
my camaro is a '95 v6 3.4L, with 78k miles. if anyone has pictures that would be wonderful.
