Frustrated-need help
Alright guys, here's the problem: I'm pulling the motor out of my '94z28. I have everything disconnected that I know of, but the motor won't pull from the trans.(m6) more than one inch. The motor can swing freely every direction, but it just won't pull free. What am I forgetting? Does the trans. have to came out first or something?
You need to remove the slave cylinder from the bellhousing(2 nuts) then slide the adaptor off. The fork will be visible then. Grab the fork and pull twards the drivers door untill it releases about 2-1/2inches. The fork will not come all the way out but its all you need. Good luck.
Kevin
Kevin
