Fuel injectors...Quick easy questions.
Doing the LE1 install and I need 30# injectors.
Are all fuel injectors physicaly the same other than poundage?
Will all Ford fuel injectors work just fine for LT1?
Is it best to avoid used injectors?
What injectors should I avoid all together?
Re: Fuel injectors...Quick easy questions.
1-NO
2-YES
3-Depends on what they are and who ya get them from.
4-Accel
I thought you were getting LE2 heads? The ford svo are very popular but remember for tuning they are 31.68 lb/hr due to being measured at a different pressure. FYI my stock fuel pump couldn't keep up with the LE2 and 30lb SVO's
