Are fuel injectors universal?
Re: Are fuel injectors universal?
Well, yes and no.... The injectors will plug in your electrical clips, but not all will hook to your fuel rail metal clips. Which is only a problem when the injectors are a little shorter such as an ls1 injector. I run SVO 30lb in one of my LT1's with out the metal clips and it fits fine and there is no chance of them blowing ouy and leaking... You can always dremmel the injector to make the metal clips slide on though... Hope that's not to complicated for you... You do know, you'll need to tune the computer if you change size's though...
07-04-2005 05:00 PM
