Fuel Line Questions 94 LT1
I'm putting my 94 Z28 back together and I was wondering if someone can suggest how to remount the fuel lines to the intake fuel rail. I cut the lines where the rails hook up when I pulled the last motor. Do I really need to get new LINES? or can I mount the ones that I cut someone how?
Chris
Chris
Re: Fuel Line Questions 94 LT1
They make a tool to disconnect them, I'm not sure why you cut them. I suppose you could buy some hose clamps and it would work...maybe double them up past the shoulder on the hard line hookup.
-Dustin-
-Dustin-
I cut them at the time because I didnt have the tool to take them off. AND I was going to go a different route with my car. Going back to the question in hand, Thank you both for the suggeston. Ill check up on speed inc. or possible hose clamp them up.
Chris
Chris
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
