Fuel Lines From Tank foreward
Well needless to say the fuel lines arent there anymore after the cats from my FLP's fried them. I called a west coast dealer since they were still open late and he said there are 3 sections of lines (tank to middle, middle to firewall, firewall to rails) can anyone verify this at all. f so does anyone have part numbers for them? Any help woud be greatly appreciated.
I can certainly verify that's how the lines route. The front and rear sections are plastic, the middle section is steel lines along the floor pan of the car.
Dunno what the part numbers are, but I'd assume your cats only fried one section of the line? That sounds like a scary prospect...
Dave
Dave
hey i posted on dfba.com but the boards down.
i just redid my fuel system and might have the lines you need.
are they different from the ls1 lines, are you looking for the rubber hose that connects to the fuel rails from the hard line?
The LS1 fuel system is totally different... its "dead ended" pressure control. Only one line to the rails. The LT1 has a "recirculated" fuel system, both supply and return from the rails. Not likely they would use the same lines... but I could be wrong.
10-31-2016 11:09 AM
87Aerocoupe
03-20-2015 01:23 AM
Deadbolt24
01-19-2015 01:29 PM
07-04-2005 05:00 PM
