which fuel pump should i get?
Re: which fuel pump should i get?
Racetronix PnP 255lph pump. Simple installation, minor modifications, very easy to work with. If you're looking for "hassle-free" I wouldn't look any further than the Racetronix fuel pump. Most retailers also sell it with a voltage booster kit, which runs a wire from your alternator to your fuel pump to boost voltage to the pump, and ultimately increase the output of the pump.
If you have a hard top, cut out the metal above the fuel tank, its not hard, their are websites to assist; I've done it myself.
I would recommend the Walbro 255 pump. I believe they are used in all newer Ford's.
Racetronix is also good. Its a matter of preference. The walbro is cheaper and I think universal. Please verify this.
10-31-2016 11:09 AM
