Fuel system not working
I changed my engine harness out of my 94 firebird v8 with a 95 harness. I tried firing it and noticed before i even cranked it over the fuel pump was not turning on when key turned forward.
I tested the wiring at the relay the pink hot tested fine, the black/white tested good for ground but the green had no reading. I traced it back through all the way to the computer to find that it also had no reading. I put 12v to the prime wire at the computer and heard the pump turn on, so i know it works.
I put the pump on a switch i heard it run and had the right fuel pressure at the rails. But when i cranked it over the injectors are not spraying.
I cant help but think the fuel pump not turning on and the injectors are because of the same cause. Any suggestions on where to start looking would be appreciated.
Re: Fuel system not working
You have two other threads started on this topic already. In the other threads, you indicate the harness is from a 96/97.
Get's confusing when there are multiple threads on the same topic.
10-31-2016 11:09 AM
squarehead
01-15-2015 07:02 PM
07-04-2005 05:00 PM
