FUSE for fuel pump?
FUSE for fuel pump?
is there a fuse for the fuel pump. i know there is a relay, but is there a fuse. i looked on the guide chart but i didnt see one? is it labeled as something else.
this is actually for my 94 lt1 caprice...but i impala site is down. any information thanks.
Looking at Shoebox's 1995 F-Body wiring diagrams, the power to the fuel pump, via the relay, is protected by fuse #5 in the IP panel fuse box. Same fuse also supplies power to the PCM IGN connection. My 94 Owner's Manual shows the same fuse for the fuel pump. I'd say its pretty likely you have one, and its also likely its the same one that supplies switched 12V power to the PCM.
10-31-2016 11:09 AM
