Gaskets needed to complete heads/cam.
Re: Gaskets needed to complete heads/cam.
Head Gaskets, intake gasket, exhaust gasket, timing chain gasket....
becareful taking the front cover off or you will need to replace the oil pan gasket also....
I would also do:
- opti-spark seal
- crank seal
- water pump drive seal
- throttle body gasket
- coolant crossover tube seals (4 total)
- EGR valve gasket
- EGR tube gasket
- opti-spark seal
- crank seal
- EGR valve gasket
- EGR tube gasket
Here's a good link to head/cam install: http://www.afrashteh.com/guide/install.htm
10-31-2016 11:09 AM
