Getting 4.10s installed
I've bought all the stuff for my 4.10s, now im just waiting for them to get here...just making sure, is there anything else i should know about drivign with them before i get them installed?
I can't wait to tear up 2nd gear on the road
Bill
Bill
I got some motive gears on ebay for around $140 new, and the installation kit from thunder racing which says:
Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. (All of the small parts and pieces necessary to RESTORE an axle to like new condition!)
so there are your crush sleeves
I hope it picks up speed...my friend has a 2001 formula and nobody around here can beat him...hes running 13.0's on street tires and just got some ET streets that will probably let him hit 12.8 or so.....needless to say I have the car that needs to beat him
I only ran a 14.1 with intake and exhaust....any idea how much i could shave with the 4.10s? I just got home from riding around in his formula, damn its so fast compared to mine....one day, one day...
Do you need a tune after you put in 4.10's? Is it just for a speedo recalibration or is it more? We will be putting 4.10's in my friends 95Z 6speed soon. The car has the usual bolt on's so far, headers, I pipe, muffler, LT4 springs, 1.6 RR's, underdrive puller, MSD, air foil, CAI. TB bypass
All you need is speedo recalibration.
Get a Solid Pinion Spacer instead of using that crush collar.
Also, a new rear cover with bolts that press onto the carrier bearing caps. I am having a brain fart and can't remember what they're called.
