Getting more power to our sh*tty window motors
Old 06-22-2003 | 04:18 PM
ZDriver96's Avatar
The passenger side window gets weak when it comes into contact with the rubber insulation on the t-top and it'll stop going up unless I open the door.
Is there a way we can get more power to the window motors?
Ive changed them out 4 times on teh drivers side and once on teh passenger side.
Anyway to fix our crappy window motors.... Do they have any Naws hook ups on them or turbo applications.... i really need to vtech my power window motors.
Old 06-22-2003 | 04:27 PM
Blue89Bird's Avatar
did you lube up the track real good when you replaced the motors?
Old 06-22-2003 | 05:43 PM
naaz90's Avatar
Adjust your windows.
I had the same problem until i adjusted the window to even up the pressure around the weather stripping. It helped out quite a bit and it doensnt leak water.
Check out shoebox's site for window adjustment guide.
Old 06-22-2003 | 05:55 PM
1996 | Z28 SS's Avatar
My passenger window goes all the way up however it struggles hard.. if I roll up/down the driver side and the passenger side at the same time, the passenger side takes about twice as long, geeze by maybe it's just because it's rubbing and not a lack of power? What is shoebox's site again for the window adjustment?
Old 06-22-2003 | 06:45 PM
Click Tech Page in sig.
Old 07-06-2003 | 01:27 AM
Fatdog's Avatar
Cool
Normally I don't chime in after Shoebox(my favorite),but if you want to buy some time before replacing the motors,lube everything in site,all tracks ,gears and everything.This bought me a couple of years of good window performance.My02(just replaced my drivers window motor thursday though).Hope this helps.(this cannot be accomplished without Shoebox's pics though).Hope this helps.
Old 07-06-2003 | 02:18 AM
96 WS6's Avatar
Try conditioning the weatherstripping with silicone dielectric grease. It was recommended and it worked very well for me, and now my passenger is like fractions of a second away from the driver one in an upwards race. And on top of that, the driver's side goes up faster too, so praise the dielectric grease.
dale3in98
02-14-2015 12:18 PM
capebuf
01-13-2015 07:22 PM
Jazsun
12-29-2014 12:14 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Getting more power to our sh*tty window motors
