Getting tired of problems please help
Ive got lot of money in my car just like everyone else on here does and Im having nothing but problems with mine and its really starting to upset me. It seems like the car is lacking alot of power Idk what could cause it, when I fire it up and I try to rev it up a little its like the rpms wont climb much you gotta give it alot of gas, its slow as hell and shouldnt be like this. Problems Im having is my fans kicking on *** soon as it starts, it smells like its running rich, and I have an exhaust leak from my collectors, could any of this cause the problem of it lacking power? Any idea about how to solve any of my problems? I tryed to have it scanned and they didnt have the right scanner at advanced auto.
Might want to consider buying your own OBD-I scanner. You can find used Auto Xray scanners for less than $100.... small price to pay if it helps you sort out your problems.
Or, consider free scanning software, like FreeScan or TTS DataMaster. Simply the cost of a cable.
If you aren't willing to use the scanner as the starting point, you might want to consider selling it, and starting over. Probably not what you wanted to hear.
Give us some more info . I see the list of mods . Did it run good after the mods were done or was that the start of the problems. Exhaust leaks can cause the o2 senors to read off. I just fixed a 95 for a guy . The car would not pull below 2500rpm . And was running rich . The cam timing was retard by one tooth.
The first step is critical and necessary...repair known problems
Second thing I want to say is any time you have a problem/issue like an exhaust leak. No matter how unlikely it seems to be related to another problem. Repair it before you do anything else. You never know what is actually related to the problem at hand. In this case it can be the source of your problem.
Last, as was mentioned above. We need far more information than you have provided in order to help you.
So first repair the exhaust leak. Then replace at least the plugs. Since we don't know what your knowledge level is, let's just say that if you haven't done anything about plugs on this car. You're in for a shock if you take it to a shop for just plugs.
Then give us more information like history. Including when the problem occurred, what was done before or after the problem showed up, etc.......
A foot note after reading your signature.
If you can't handle this problem. You had better give up the 355 build. If you think you have problems now, you have the potential for much bigger problems.
Moshbmx1
01-20-2015 03:27 PM
