GM 3" exhaust ball flange for single cat?
Does anyone know where to get the 3" exhaust ball flange that's like a stock one on the rear end of a single cat?[bolts to the catback, and the hanger]
I want to get two, one to replace the cat, [without paying 100 more for the flange being on the new one], and also one to make an off road pipe that can be swapped in easily...
Have tried the usual search engines, etc.. can't seem to find a source..
Thanks!
Charlie
Thanks!
Charlie
http://www.drgas.com/product.asp?id=9
I just bought one from them last month to make a new ORP out of a 18" dynomax bullet. You have to get the ball and cone set but it's only $33, not too bad plus shipping was free. They shipped it out pretty fast too, good place.
Thanks for the source..
What I am looking for specifically is the stock GM single cat flange
http://www.all-catalytic-converters....converter.html
Go halfway down the page to # 9118.. that's the flange I need shown there..
So noone knows of a source for the 'stock' GM flange?
Some people told me you could get one at a muffler shop when I was looking for one. I tried a few places and they wouldnt sell them (if they did have just that piece) they weren't too interested in helping me out with one unless I was bringing the car in for work was the impression I got. I got the part in the link above and it's basically the same thing, it's a 6" long piece of 3" dia pipe properly flared with a 2 bolt flange to bolt up to the catback fitting. I'm pretty sure the only way you are going to get that 'exact' flange is to cut it off a cat.
I figured as much since cats w/o that flange are a lot cheaper that with.. they corner the market on the flange.. I also suspect muffler places have these available[ otherwise where do the stock replacement 'flanged' cats come from?]
The problem is that I want to use the stock hanger.. and also make an ORP to swap out easily..
One could probably make that flange out of say 1/4" aluminum plate, etc.. [but 35 bux for just the ball ended pipe then becomes a bit 'much'..]
I do have the stock cat and Y pipe, but prefer to leave it intact in case I go back to stock someday..
Thanks for the replys Gregg...
Any one else knows [or has an aftermarket cat lying around that has one on it] please post..
jasonduaine
04-01-2015 08:09 PM
01-05-2015 07:14 PM
