GM847/cc306 dyno chart?
Old 03-07-2008, 12:33 PM
  #16
LSWHO's Avatar
It made 340 through a stalled auto? Did you lock the converter for the run?
LSWHO is offline
Old 03-07-2008, 01:02 PM
  #17
'94 Bad A Z28's Avatar
Yes... unlocked it made 335.
'94 Bad A Z28 is offline
Old 03-07-2008, 02:14 PM
  #18
MEAN LT1's Avatar
Im really going to have to make a trip down there for you I see.
MEAN LT1 is offline
Old 03-07-2008, 06:02 PM
  #19
brain's Avatar
Originally Posted by JoeliusZ28
When did i ever say anything negative about the 847?
I personally think the duration is a little too extreme for what is optimal on an LT1. Sure it might make more power... but i think it demands too much RPM for a lasting combo. If you dont mind revving to the moon, then the 847 is the way to go im not even going to argue that.
I guess negative is the wrong word. Just as you say that you have to rev to the moon, and that it demands too much rpm, is a false notion. The 847 in my car is making peak power at 5800, making the ideal SHIFT point around 6400ish. If you make peak power AT 6300, like the 230/238 suggests, then your shift point is nearer to 7000. Sounds like a bit closer to the moon to me.
Streetdemon - I know what you mean about dynos not meaning much, but even the people that say they aren't worth much change their tune when they get the numbers they are expecting, or it exceeds their expectations. Franks car was an exception I believe, I think it was a lightweight racer. Hell, I weighed 400lbs when I went the times in my sig. Put a 150lb driver in my car and it would shave off a few tenths. All my friends say I can't drive a stick, so put an experienced driver in, and you've got a better time. A dragstrip has too many variables and I've seen too many heads/cam combos running low 13s to even consider trusting them completely. I remember when a good heads cam setup ran 110 in the traps. Poop on that I say. I would have LOVED to do a 6000 rpm clutch dump on slicks in my car, but it kept breaking rearends and I didn't have $2K to drop on a nice one. FWIW, I think dynos are very reliable and valid if done correctly.
brain is offline
Old 03-07-2008, 06:49 PM
  #20
street demon2k3's Avatar
My car has never dynoed well, but it has always been a tool to see how my car is running. Last time I dynoed I found out my car was going lean up top(14:1 AFR) which is pretty bad. If I hadnt gone I would have never found my problem. If there is one thing I love about the 847/306 is that they sound wicked and really pull hard up top.
BTW- I weight 170lbs so If your ever in south Tx let me know so I can race your car...LOL!!!
street demon2k3 is offline
Old 03-07-2008, 06:52 PM
  #21
Oh and Frank's car weighs 3300-3400lbs with him in it IIRC, so its not really an all out race car. I think he mentioned he drives it frequently on the street too.
Old 03-07-2008, 08:24 PM
  #22
Yes please do!!!! Lol....
Old 03-07-2008, 10:29 PM
  #23
Frank95z's Avatar
Streetdemon you are correct my car weighs 3327 and i do drive it on the street. I went 11.40 with a 210/224 cam very streetable. Then I went 11.15 119.86 with a custom Joe O cam but that cam makes low vaccuum(not cool with power brakes) and is not so street friendly. I made 331 rwhp unlocked with the 210/224 and 357 rwhp unlocked with the Joe O custom cam. Frank95z
Frank95z is offline
Old 03-08-2008, 02:46 AM
  #24
marshall93z's Avatar
That's nice power unlocked.
marshall93z is offline
Old 03-08-2008, 07:29 AM
  #25
brain's Avatar
Frank, I hope you don't think what I said regarding your car was negative in any way. I knew your car was a good bit lighter than the typical fourth gen though. I was under the impression that the 3300 lbs your car weighed was with you in it. Please correct me if I am wrong. Mine weighed more than that before I even got in, lol! FWIW, there was a guy around here with a 95Z that had done a lot weight removal and it ran crazy for a bolt-on car. I think it was running low 12s around 110 or so.
brain is offline
Old 03-08-2008, 09:51 PM
  #26
JoeliusZ28's Avatar
that site says "operating range" meaning probably peaks before 6400.
JoeliusZ28 is offline
fift5
11
10-01-2015 10:31 AM
Daluchman1974
09-11-2015 06:12 AM
tdigger9899
09-07-2015 10:56 AM
RallyRed701/2
07-27-2015 02:55 PM
Strick
07-14-2015 07:28 AM
Quick Reply: GM847/cc306 dyno chart?
