GMMG install problems.
I went to install my gmmg catback this afternoon, and the hangers dont line up very well at all. The exhaust will be tucked up way too high if i slide the hangers in. I was thinking about shimming them down with some washers or something, but im not sure if it will be enough. Has anyone else had this problem?
Re: GMMG install problems.
I'd like to help but I had to fab mine to fit from an LS1 to my LT1. I just stole the stock hangers off my stock catback and bent them to fit my needs. Is it just the rear two or the third by the PHB also?
-Dustin-
-Dustin-
-Dustin-
-Dustin-
theyre all the same
ls1, lt1, it's still the same catback
i think i do remember pulling down on the mufflers to get the tips just right (actually, just pulling on one side to get them level)
yea, i'd do what dustin said and just try the stock hangers, maybe it'll work
I think thats what ill have to do, It wants to tuck up so high that its right afainst the heat sheilds, and i dont even have both sides hung yet. Ill figure something out i guess. Thanks for the help guys.
Originally Posted by CamaroSS30thAnn
my drivers side tailpipe was higher than the passenger b/c of teh hangers , i shimmed it with washers and it came out just fine
Not sure if they are universal, but mine was used off a LS1 so I had to mod it a bit to fit the way I wanted. Originally it wanted to push the tips against the bumper. 2 Stock hangers, welding, grinding and a pry bar later, it works great. Good luck.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
Originally Posted by 95_LT1_6SPD
How much did you have to shim it, that was my original plan. Ill give it a shot.
say half an inch on teh driver side, maybe 3/4 cant really remember. couldnt do it too much or i wouldnt be able to bolt it back up lol
They sell hangers for the LT1 when buying their system. The LS1 hangers are different. Just for future reference when someone wants to buy their exhaust for the LT1. 20 bucks for the kit.
we did get the lt1 kit, all the hangers for the lt1 etc, the only thjing is the way tha hagar holds the rubber piece the exhaust on the driver ide eems to be up slightly higher, its not a big thing just some ppl like are **** about things lol
