Going from LT's to Mid/Shorties
#18
Originally posted by 95Blackhawk
Personally, I think people put too much emphasis on the LT's anyway. All the HP they produce is up top anyhow and that is really only usable at the drag strip (oh god here comes the flames). For someone like me who will autocross, the shorties worked out fine.
Hey you can see by my sig that I have the stock cam and making HP to 5900 RPM...just about perfect for me. I don't need it any farther up than that.
Ben
Ben
Longtube headers will fatten up the low end torque more than shorties. Shorties are more of a top end header...
#19
I have experience with Shorties and LTs, I currently have the Hooker LTs on the car but have not seen any real improvements over the shorties I was running. This debate will never die but if you were looking for shorties and needed to run thru emmissions I would look at the Edelbrocks. I have seen these headers go really fast.
I have thought about swapping back to the shorties but dont want to hassle with more exhaust work....
Good luck!
Good luck!
#21
if your interested I will be having a set of used SLP headers and a Y-pipe with a high flow cat on it for sale in a week or so. Not exactely sure when but whenever my motor gets pulled I can take them off at that time b/c I'm going to LT's at that time. The slp's are stainless, but darkened due to heat cycling. The Ypipe I think might be custom and I can shoot pics and email them if your interested. I'd let the combo go for $450 plus whatever shipping will be.
lmk
John
lmk
John
#23
Originally posted by TheHeadFL
When are people going to stop believing this misinformation about longtube headers?
I'm would love to see some direct dyno comparisons though holding everything (including y pipe size) constant but varying the header primary length .
-brent
#27
When people test things and 'vary' a variable like primary length it doesn't literly mean that the component is adjustable. I think most people understood that i meant a comparison of two different sets of headers (thats how you vary primary length) on the same motor with the same catback(held constant).
I wholeheartedly agree with this post by Fred. Notice that this particular example is on a high rpm motor.
Originally posted by Injuneer
For the single cat models.... definitely among the best non-LT headers out there. I push almost 800HP through them. I bought them used from a buddy who was putting over 850HP through them. He dyno'd them at that level, then installed Hooker LT's, and lost HP. Only when he changed the cam and pushed the engine over 925HP did the LT's make more power.
The advantage of the LT's appears to be a very broad torque curve.... and that is the theoretical advantage of a "long tube"... more torque down low due to "tuning" the scavenging in the runners to lower rpm. A shorter tube moves the torque curve up, and that's why on a very high HP engine, that is only operated at 5K rpm and up, for example, mid- or short-tube headers may show an advantage under some condition. But the LT's seem to be killer for the street.
#28
Originally posted by WS Sick
I hate California.
I hate California.
Anyway, as I said, nobody will fab up a Y pipe, and if any law enforcement personnel see that under my car, bam!!! $2500-$10,000 outta my pocket.
I"m looking at the Edelbrocks and MAC's at the moment, seem to fit my budget of $300-$400 and I can get them coated locally.
I figure with a 396 turning 6500rpm, moving a lot of air, I guess there's a point where it doesn't really matter a whole lot, I'm not in a championship so it's not gonna ruin my season or anything. The minimum I will see on a road course is about 3500rpm in some turns in 2nd gear.
I really appreciate your input on all of this people, thanks for your time, and I'm still debating between MAC's and their associated problems but major benefits of a longer tube design over the Edelbrocks.
Thanks again.
#30
Originally posted by Fastbird93
For those who said it already....
Arizona Speed and Marine headers. Nuff said.
Dan
