golen engines
golen engines
has anyone on here ever talked to these guys or bought a motor from them. i want to buy a 383 shortblock from these guys and they seem to be very good. can i get some feedback from you guys on this board about them
I've only read good things about them. This for example is one regarding the very product you speak of.
http://www.golenengineservice.com/html/gmhtp_1d.html
2nd part.
http://www.golenengineservice.com/html/gmhtp_2a.html
Final part.
http://www.golenengineservice.com/html/gmhtp_3a.html
GMHTP magazine likes Golen.
2nd part.
Final part.
Do a "search". In the past month, I believe there was a report of a broken crank snout in a Golen-built engine. I don't think the original post ever clearly identified the cause of the failure, but there were a few responses discussing possible issues.
I purchased this engine in it's broken state and had it analyzed to find the cause of failure. They used a cast Eagle crankshaft which broke near the front main bearing. The oil galley plug directly above the journal was pressed in too far which starved the front main of oil, causing it to overheat, weaken, and ultimately break. I was told by someone at Golen that "Eagle cast crank failures are common," and they would not stand by the damage. The engine failed at low RPM after 400 miles. I have since rebuilt the engine using quality parts using a quality builder.
I wouldn't use them.
I have heard good things about them, but I have also heard bad things about them.
Besides the bad things I have heard in this thread about them the other one was they had an engine that refused to quit smoking and they would not fix it.
We have built many LT1 engines with Eagle cast and forged cranks. We also offer upgrades to Compstar and Callies crankshafts and rods. Check out our website then give me a call if interested.
www.cpengines.com
Jacob Cook 317-697-6061
www.cpengines.com
I was thinking of this thread... but the OP never really responded on the details of the break, or the cause. In fact, that was his last post on this site, and he hasn't even been back to the site since 10/22.
https://www.camaroz28.com/forums/sho...ighlight=golen
I've been looking at what to do with my engine......
I think I'm going to go with a build from ATK High performance. They are offering a 355 4-bolt short block $1299 shipped to my door. There are no forged components in the build. It's what I'm looking for.....good solid bottom end 4 bolt main that will handle 450 at the crank. I'm not sure I can do much better than that on rebuilding my short block correctly(I'll make it a 383 over the next couple years as I get the money).
http://www.high-performance-engines.com/
This is the 355 short block....just a stock rebuild....($1299 shipped)
http://high-performance-engines.com/...duct_Code=SP34
....and there is a 383 short block too......all forged components....($2799 shipped)
http://high-performance-engines.com/...duct_Code=SP33
i have seen a couple of the cast eagle cranks and what they are doing is grinding metal between main journal 1 and rod journal so thin that they are loosing strength. i believe it is for weight lose. SCAT uses the same company in china to make their cranks but they do not grind on this area. also the grind and polishing on the eagle cranks is horrible. i did up a quick picture here where i have personally seen breaks. and i also have an example of a crank where the rear actual broke.
man these issues really make me glad that i went through jasper engines and that i didnt go through golen(i was gonna go through them). has anyone had any issues with jasper?? i have had my engine now for 11 months and they warrantied it for 3 years/100k miles and she has been very good to me as well as not a leak since putting amsoil synthetic in so i think i got a good deal!
