Good or bad ideal?
Good or bad ideal?
Hay what do you all think I got 96 lt1 camaro A4 getting ready to install a set of pacesetter longtube headers and a magnaflow catback system also plugs & wires and i'm pulling the engine out from the bottom it look like it's the best way to go to install all this what do you all think and what should I look out for any info will help thanks
Re: Good or bad ideal?
You're creating a lot more work for your self by pulling the motor to install headers. You'll have to lift the motor a bit to get the headers in but that's far from actually removing it. You wouldn't be able to install the motor from the top with the headers bolted on. So if you're set on removing it, out the bottom is you're only option.
Yep! set on taking it out from the bottom also I while i'm at it I think it would better to do some other things while it's out could be wrong?
Well I here how long it take to put headers on and spark plugs in so I feel in that amount of time I can have the engine out and no I not just doing headers! just was looking for some insight
Fbodfather
25
06-21-2002 04:12 PM
