Good low end cam??
#33
#35
The big reason i am doing this is bc i HATE RICERS and i would like to beat the mostly stock LS1's and the WRXs and cars like that. When i pop my hood and i have a 305 tbi im not proud of that at all u know but when they see a LT1 that will be sweet then have the power to back it all up.
thanks
kevin
thanks
kevin
#36
if you don't have an F-Body, i.e. you have a car weighing 4000+, you should consider an RV type cam. They are configured and designed for pulling power. I.e, pulling out of the hole. The Crane 210/224 or the LPE 211/219 fit that profile.
I run the 227 in my 97SS and gets it on out of the hole. JMHO
#37
Low end tq is a lot more fun on the street then peak power anyway. It sucks getting pulled off the line by minivans unless you go 75% throttle
#38
#40
I was thinking about swapping heads but then i know in the future i will buy i really nice set. But for you guys that dont know i am putting this into a 1990 camaro with me in the car its like 3300 or so. Let me ask you guys just to see what you think if i go with this set up will it be fun and pretty fast like mid to low 12's?
1 Good complete rebuild .30 over
2shorty headers, y-pipe, flowmasters
3 3000 stall converter
4 Good tune/ chip
5 Lingenfelter 211/219 cam
6 3:73 posi
7 700r4 high performance **** kit w/ corvette servo
thanks
kevin
4 Good tune/ chip
6 3:73 posi
thanks
kevin
It is a great cam. I had it with LPE heads/intake/LT's/ORY/3.73 gears and was able to get a 12.09 @ 115.5. Averaged around 12.15 to 12.2 @ 114.5 to 115 through the traps on a sea level track. While it had Edelbrock 1 5/8" shorties attatched to the stock exhuast including stock cats it turned 12.6 @ 110.5mph at a 600ft. ele. track. Car would get 27mpg on the highway and high teens to low 20's in the city. Drove just like stock. It used to be dubbed an "RV cam" back in the day because of its low end grunt. I think my power peaked right around 5900rpm. Shift points were at 6200rpm. IMO you won't find a better performing cam for what it is. As far as lopey goes, if you run it with cats then it'll sound stock. No one will be able to tell except you and someone who knows what to listen for. W/out cats it'll have a bit more of a lope to it, but nothing to write home about.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
