got new clutch ,but no instructions
got new spec clutch today but they didnt give me instructions on what to torque everything down at also i am not sure which side of the disk goes against the flywheel. it might be a couple of dumb questions but i just want to make sure before i put it together. Any help would be great.
That is the reason that i'm gonna get mine changed by a shop, they get it done fast and there is less chance of problems later. A couple of my buddies said we'll help you put it in. One of them has a dad that was a master tech for many years, i still passed on the offer becuase he wasnt a master trasnmission and clutch tech.
Guess this got pushed back a bit on ya. If you found out then great, otherwise here are the specs on my 94 which should be good to go.
P Plate - 22ftlbs
Flywheel- 74 ftlb
B HOUSING -35 ftlbs
Tranny- 26 ftlbs
Clutch disk- flat side to the P.P. ie raised hub part to the engine.
Use Thread lock.
P Plate - 22ftlbs
Flywheel- 74 ftlb
B HOUSING -35 ftlbs
Tranny- 26 ftlbs
Use Thread lock.
