Greater than 91 Octane in Utah?
Re: Greater than 91 Octane in Utah?
What elevation are you located at? The higher you are above sea level, the lower the octane requirement for your engine. That's why the don't sell higher octane fuels in "high elevation" states.
The gasoline doesn't act any different at higher altitudes. Its the fact that you are pulling in thinner air, and not able to burn as much fuel, producing much lower pressures in the combustion chamber. A given engine's octane requirement drops more than 1 octane number for each 1,000-ft increase in elevation.
What about for a decrease in elevation? There are some parts of this world that are really under sea level. What would be the outcome of the air be on the engine when the elevation goes below sea level?
Originally Posted by DavesLT1
aren't places like this usually like Death Valley? would you really want to be driving when it reaches 140 degrees?
So if my car requires 93 octane at say 1000', it should run fine on 89 octane at 5000'? Or in other words, if I run quality 91 octane with stock compression ratio at 5000', I should never have any real knock? (assuming a clean engine)
A stock LT1 engine should run without knock retard on 91 octane fuel, at 5,000-feet. Tendancy to knock can be increased by high coolant temps, high intake air temps and carbon buildup in the combustion chambers.
Lol, I think one of the southern states is completely below sea leavel, Louisiana? Don't remember. But Death Valley is just insane. It would probably reach more than 140 on the road, and the temps of the engine combined.
Almost, The place you are talking about is called New Orleans. There's actually a levy built around the town. Elevation is in the 300's up here in the NORTH where I'm from.
08-24-2015 06:41 AM
05-08-2015 11:30 AM
