Ground clearence with LT's and Eibach pro-kit???
Would it be safe to use LT's if the car is lowered with Eibach pro-kits or similar springs??? I don't want to slam the car, but I'm just wondering if I would have any clearence issues?
Re: Ground clearence with LT's and Eibach pro-kit???
umm...yeah. you're gonna have some clearance issues with LT's and dropping the ride. i have mine dropped with LT's and true duals. its rough. you will not be able to clear speed bumps. if you have more than one person in the car, the occasional bump will cause you to scrape at times. i dont really mind it that much (due to most of the roads i have to travel on are flat and smooth), but just make sure that your aware of these issues.
autoxr166
09-25-2015 04:21 PM
