ground wire from PCM
why does it have to be replaced? is the entire wire damaged?
www.shbox.com may have some schematics to help you out. if not then you should get yourself a haynes or equivalent.
I'm not sure if it needs to be replaced all I know is that the car is getting intermitent spark and i checked everything and all has power so I'm guessing a bad ground, also my wires are all pretty ****ty from sitting for the last 5 years.
