guide plates
guide plates
are you guys usin' flat guide plates? ilike the price of the trickflows. its for a 847 cam w/ 1.6 rockers.can i get a part number of the trick flows everyone is using?ive had to slightly notch guideplates before, so id rather do that than spend $50 on some isky's.but, if the isky's are the only thing that work, ill use those.
honestly if i did it over again i would go with the iskys, they cost more and are a little harder to set up but i think it is worth it. i ended up having to end mill my trick flows a bit, but i dont think that is normal.
the part num for the trick flows is
Trick flow 30400623-8 guide plates.
ok, i just dug up an old post ,that answered my question.a guy w/ an 847,1.6rr ans comp 5/16 pushrods typed that his was rubbing pretty bad.i guess isky's are the only way to go w/ my combo.
NewsBot
09-30-2015 04:20 PM
NewsBot
09-14-2015 09:20 AM
