Guideplates question(semi-emergancy)
Hey guys, I grabbed those 1.5 long slot stamped rockers to hold me over until I could afford pro-mags... well they dont appear to be self aligning....
What guideplates should I get and where can i get them ASAP. need them like yesterday.... car needs to be running b4 the end of the week
thanks
-ERic
thanks
-ERic
The rockers are Jegs part number 778-66905
When i looked at the tips of the stocks and the tips of these.. the stocks had a noticable grouve.... and these are flat...
Sorry bout the first post lacking specifics... let me know if you need more detail...
-Eric
-Eric
Those are self-aligning, just like the stock ones. The ball washer and shape of the rocker arm keep it centered. Besides the slot, the only real difference between those and the stockers is the roller tip.
Probably nothing, except they're only $3.00 each, so $20 for the set.
Probably there are alot of guideplates that might work, but they have to fit the LT-1 head.
As long as it's made of good steel a guide plate is a guide plate, you know?
-Dave C. '97 Z28
-Dave C. '97 Z28
Originally posted by RE AND CHERYL
Whats different about the GMPP guide plates that makes them better than say a set from summit?
Here is something interesting.
I have a GMPP catalog from 1998, and in it I looked up the guide plate 14011051 that we're talking about here.
It says:
14011051 - Guideplate (Aluminum Bowtie Head)
This hardened steel guidplate has the correct pushrod spacing for the aluminum bowtie heads.
Tech Note: This guideplate is identified by the stamped number "05." These guide plates should not be used with slotted tip rockers. Pushrods slots should be 0.365".
So it doesn't mention 6-cylinder engines in this description.
-Dave C. '97 Z28
It says:
-Dave C. '97 Z28
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
