guys with duals, what mufflers are you using
#16
what did you guys do about the fuel line issue?? I am getting ready to run duals with 40 series flows but the fule lines run the whole length of the drivers side and I dont want to have that pipe up against them
#17
I had the dynomax bullets but they were extremely loud, even at cruise. I got the Borla XS series mufflers which are AWESOME. Extremely quiet, with no power loss. Some mustang mag did a review of them a while back and they had the lowest decible rating and highest hp rating on a test motor. You really can't even hear the car at cruise. It has the "slightest" resonation at idle, but really mild. I definitely recommend them!
#18
i didnt do anything to my fuel lines, just make sure you keep a little distance between them and the pipes.
i dont want the car to be too quiet, i like having it loud just not this loud.
#19
You know you should just run the pipes over the rear then put those chambered pipes on in the back as two mufflers.Have the right side cross over to the left and left to right.Put the two mufflers were the stock was and that should still so good.You can always run cutouts for the track.
#20
