h beam rods?
h beam rods?
http://cgi.ebay.com/ebaymotors/SBC-C...QQcmdZViewItem
would these work in a 1993 to 1997 lt1? what do you guys think about them?
what about these h beams? not to sure if they are the same ones or not.
http://cgi.ebay.com/ebaymotors/FORGE...QQcmdZViewItem
what you guys think about these pistons? would they work in a lt1?
http://cgi.ebay.com/ebaymotors/sbc-C...QQcmdZViewItem
im thinking of doing a rebuild with some forged hbeams and forged pistons with a stock crank. going for 450ish whp na and then maybe a 200 wet shot at the most, but probably just a 150 wet shot.
any opinions?
any opinions?
I was looking to build the same setup as you not too long ago, but then changed my mind and decided to go w/ a fully forged bottom end.
I still have the set of NIB Eagle Forged H-Beam 5.7" rods I was going to use along with Forged Mahle .030" Powerpack(pistons, piston rings, pins, and wire locks) also still NIB that i'm trying to get rid of if your interested... I will seperate, or make you a deal if you buy both..
Here are a couple pics.. Let me know if your interested and I will take some more if you'd like.
Mahle Pistons
Eagle Rods
Mahle Pistons
Eagle Rods
