H/C LT1 results
#16
Re: H/C LT1 results
Your numbers are fairly close to my last years track passes...Check out my sig for what a 1.55 60' would do for your 1/8th...Have since changed a few things Kooks LTs, EWP and Bogarts with 275 50 15 M/T Radials...trying for 1.4Xs...
--Alan
--Alan
#17
Re: H/C LT1 results
i run 275/50/15 mt radials on my car. Just about all the bolt ons, a cam, and some gas. 1.53 60 has been the best i've cut so far. Only suspension mods are lca's and relos. car probably weighs 3560 or so with me in it maybe more. Try and find a track that will prep it and try it there.
#18
Re: H/C LT1 results
Originally Posted by MeanGreen97Z
Yup get that bad boy to hook up and you should see some 1.5x 60 foots... then your lower 7s will come. Drop the tires to 12psi or so psi and heat em up like crazy (John Force them is what I do) and you should get there.
#19
Re: H/C LT1 results
--Alan
--Alan
#20
Re: H/C LT1 results
Believe it or not, I ran the times in my sig with 20 psi and a 5 second burnout in 2nd gear @ 4000. When I nail it off the line come 11-4-06, I expect a 1.50 60ft.
If your car is working, the MT DR's will hook.
Dean
Dean
#21
Re: H/C LT1 results
Originally Posted by n20fed
What hp on tq numbers are putting dyno and on what kind of dyno? Also, what rear gears are you running?
--Alan
#22
Re: H/C LT1 results
When I ran the the 11.50s I was 381rwhp/370 rwtq on the Dynojet...Changing to Kooks stepped LTs and an EWP and the numbers are very similar only now on a Mustang Dyno which is what I will continue to use..I run 3.73s in my 12 bolt and a 3600 Vig...
--Alan
--Alan
#23
Re: H/C LT1 results
what is your race weight, and what tranny? If a t400 do you have a transbrake?
--Alan
Redbird
08-12-2002 08:51 AM
