Hard start when hot or after driving
My cousin has a 97Z that is stock besides exhaust and cold air intake. He has a problem starting it after driving it. If it sits all night, fires up with no problem everytime. During the day, even after sitting for 8 hours it will take 3-5 seconds to start. Any ideas?
Re: Hard start when hot or after driving
Same issue here but I haven't figured out my problem yet. I still need to check my fuel pressure though and see if maybe the pump is losing pressure or for leaking injectors. It was either those two things or possibly the coolant temp sensor.
That is the advice I got from some of the members here though.
I'm leaning toward fuel tank vent valve
The problem gets better the longer it sits. So to prove (or disprove) my theory open the gas filler cap every time he parks it.
He could also disconnect the vent valve behind the driver rear wheel and try it a few days with it disconnected. However that could throw an evap code.
It sounds like it has a restriction and is not letting the air into the tank as fast as it should. After sitting long enough the air eventually gets in and the vacuum is released.
I had start symptoms like what you are describing. Turned out to be the fuel pressure regulator (ruptured diaphragm). It's a simple check. Pull the vacuum line off and check for any sign of fuel. Line should be dry.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
Alex Barnes
01-24-2015 10:21 PM
