Hard starting
Old 02-09-2004, 12:41 PM
  #31
z28poweredlt1's Avatar
Originally posted by slopokrodrigez
Then I would say the tests are the only way to find out for sure.
alright well i jsut checked the fuel pressure regulator white the engine was running and gas came out of the vaccuum side, so the part is on its way and we'll see what it'll do.
z28poweredlt1 is offline
Old 02-09-2004, 01:02 PM
  #32
damned fpr was 60 bucks, do i have to remove the whole fuel rail to change the regulator?
Old 02-09-2004, 01:27 PM
  #33
GreenDemon's Avatar
Yes, you have to remove the fuel rail- the fpr is under the cowl, its a pita just to put a gauge back there, and No, it's not very hard at all- Take the fuel lines and four screws off and pull off the fuel rails (carefully) with the injectors... after you unplug and label them, of course...
GreenDemon is offline
Old 02-09-2004, 01:30 PM
  #34
scoobysnax83's Avatar
Originally posted by z28poweredlt1
haha well atleast i got a new fuel pump in!
you upgraded it right?
or I'll be the one laughing
Edit: I see above that you upgraded to a Walbro...good call
scoobysnax83 is offline
Old 02-09-2004, 01:32 PM
  #35
no i jsut went with oem becuase i'm an ac delco wholesale distributor and it was real cheap
Old 02-09-2004, 01:34 PM
  #36
well, atleast you have the access hole for when you want to upgrade later. So you can get stuff wholesale, ehh. Wanna make some friends.
Old 02-09-2004, 01:42 PM
  #37
tell me what you need and i'll let you know
Old 02-09-2004, 01:48 PM
  #38
nothing really... but I'll keep you in mind
Old 02-09-2004, 04:54 PM
  #39
IanZ28's Avatar
OMG, like the first 10 posts in this thread were full of such BS I was gritting my teeth reading it.... Slopok, thank you for ending the garbage..... Definitely FPR or Injectors
The replaced fuel pump fixed my starting problem.
IanZ28 is offline
Old 02-09-2004, 06:21 PM
  #40
TArider21's Avatar
Thumbs down Hard Strating
I wish my problem was only the FPR, gonna put walboro/racetronix fuel pump in hopefully this weekend, dropping the tank!
TArider21 is offline
Old 02-09-2004, 06:32 PM
  #41
pvkn1ght's Avatar
my problem is similar (not trying to hijack thread )
1. the car, in general, takes around 5-6 seconds of cranking to start, much slower than other fbods i've owned/ridden. but it starts strong after that.
2. if the car sits in a 15min-1hour window, it will start very slow with low stumbling rpms followed by 15-20secs of high revs at 2000rpm. if i turn it off and try again, it's fine.
3. i've cleaned the tb, iac, replaced a slightly ripped intake elbow with a new 1LE, have nto yet replaced fuel filter
4. i notice that in the 'ON' position (when the pump primes with that whirring sound), the pressure is at ZERO. i read somewhere it should be at ~40psi? the guage shows pressure when driving though.
THANKS FOR TAKING THE TIME TO READ THIS. please help
how do you check if the fpr is good/bad? something about a shraeder valve very noob @ fuel syst. thanks
Brian
pvkn1ght is offline
Old 02-09-2004, 06:45 PM
  #42
Brian
try this, pull off the little vaccum line on the fpr after the engine has been run for about a minute or so, if there is any gas or moisture from gas then you'll need to replace it.
Old 02-09-2004, 06:49 PM
  #43
well sure enough the number one cylinder's injecter would freeze open once the pulse stoped, that explained the fuel pump pressure dropping rapidly when i shut the car off, so i cleaned all the injectors with the ultra sonic machine, new filters and seals and tested again 3 times, no problems and all of the injectors flowed the same on the chart! replaced the fpr cause that was bad too and now the car starts up very very well , I'll find out tomorrow morning how she starts and I'll post again, let me know if you need anything new acdelco and i'll see if i can help because i know you sure helped me, thanks man.
-Mark
Old 02-09-2004, 06:52 PM
  #44
all that matters is that its fixed. Hey how much does a shop generally charge for cleaning injectors. And, would it be cheaper if I brought them in already off the fuel rail?
I'm thinking of doing it for the hell of it
Old 02-09-2004, 07:36 PM
  #45
badass383's Avatar
badass383 is offline
Quick Reply: Hard starting
