Hartland Rockers
Hartland Rockers
Is anyone running these?(Hartland Rockers) Just Wondering if there any good or if I should keep the GMPP Rocks. The lift I'm seeing is with in .07 of the max that GMPP rocker can take. How does the weight of the two compare and anyone know the diameter of a comp 977 spring? Thanks cameron
Are you talking about harland sharp rockers? They are good aluminum rockers, but i usually try to stay away from alum rockers on street cars. Its better to just get steel rockers and have peace of mind that you arent gonna break a rocker.
If its a weekend warrior or a trailor queen, then yea... they are good for your setup all the way.
I have a friend with a set of these in his track only foxbody. He's never had any problem, but its not his DD.
