Head bolt question
Head bolt question
I was looking in the haynes manual and it said the 97's LT1 like mine are torque to yield head bolts. Could non trq-to-yield bolts be used instead? No real price difference just a plain "will it work question". Thanks all.
That was what I was thinking about, rather than buy new bolts everytime I take the heads off.
Why do they work better? I would think it would be the opppsite as it would allow flex, ie not as good a seal? Just a thought.
TTY bolts stretch. They have 3 positions. (1) elastic---which means they should return to original ( 2) plastic which means they will stay stretched (3) break point. The TTY is between (1) and (2). The clamping force is more constant and manufacturers shoot for larger margins of error in specs to compensate for assembly-line inconsistancies.
As Shoe mentions, a good set of ARP bolts with proper torque is the way to go. JMHO
