Head coolant line problem
After I put in my new heads, I've developed a small leak that seems to be coming from the back on the passenger side head. I've used both rubber washers with high temp rtv and tightening the bolt a few times, but still I have a leak. Any ideas?
yep no rtv... Make sure your using the right head seals.. There are other seals that will look like they will work but will leak.. Just make sure they are the correct part and undamaged (if u installed your old ones or used ones)
10-31-2016 11:09 AM
