Head Gasket and Coolant Ports
Old 04-04-2011 | 11:14 AM
tree95zlancca's Avatar
Question Head Gasket and Coolant Ports
I have a 95 Z28 5.7L A4 that I am currently in the middle of installing a rebuilt Lt1 into. The old engine blew a head gasket because of a cooling system problem that allowed the engine to overheat while my wife was driving it (what check gauges light, I didn't see anything!). Anyways, I took off the head from the old engine to check the place of failure, and noticed that the coolant ports on the head and the cast iron block are quite large, but the hole in the gasket is very small. Is this normal?
Old 04-04-2011 | 11:58 AM
RamAir95TA's Avatar
Re: Head Gasket and Coolant Ports
Which gaskets are you using?
Old 04-04-2011 | 02:18 PM
These are the old gaskets on the old motor.
10-31-2016 11:09 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Jazsun
12-29-2014 12:14 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: Head Gasket and Coolant Ports
