Head/header bolt thread question
Ok so has anybody helicoiled the header threads on their head, as preventative maintenance? I mean like the first and last threads maybe? I was thinking about doing it since the heads are on a stand right now. It just seems the aluminum threads are prone to weakness/stripping. I know it is not possible to do this once the engine is in(without removing heads), and wanted to run this by everybody.
no no no. dont worry bout that. the only time there a problem, is when either someone crossthreads them (cause there headers holes arent lined up properly? or just not taking your time), or if the bolt breaks because the bolts are old/fatigued and the orig. mannifolds are warped. if you got them out no problem, just buy some nice bolts (S/S and never worry bout them again) and add some loctite so they dont gall when you remove them years down the road. I put my header bolts in 5 years ago, they came out like I just put them in.
Long story short - IMO, its worth it if you can put helicoils in without messing up. Its just good insurance down the road.
I have used a helicoil once, and I am familiar with how to put them in. If I put some in, what do I need to watch for? I mean if I use the recommended kit (thread size), the drill size is ok correct? I would poop my underpants If i messed up my heads.
I noticed there are 2 types of the helicoil lengths for this. .562 and .750
UPDATE: after thinking this over, I am not going to mess with them unless I have to. I will put these in if/when I strip threads later.
yeah sorry, meant anti sieze. got a 3 week old baby and im a little sleep deprived.
just all the hassle of doin it is the reason I recomend not doin it, and you need to get it straight too. its way too easy to drill a little crooked. all for nothing if there fine now. if your good at doin them, no it wont hurt. but why?if you jsut feel like doin something, come over here and finish putting my car back together. cause for the reason listed above, I dont have time right now.
Ha, mine is 7 months old, no sleep still. I feel your "pain"
Yeah that is my fear. I am afraid of drilling one just a little crooked, and having the bolt not line up with the header or worse damage. Trust me I am not bored, LOL. I can barely get this engine project done. I am limited to every other weekend on it right now. I am in really no rush however, and wanna make sure to do things right the first time. (which is why I wanted to know if I should tackle the helicoils while motor was out.) Yeah so I just couldn't drive myself to drilling out good threads like that, with risk involved.
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
ChrisFrez
11-23-2014 10:33 AM
