headers! headers! headers!
im sure there has been way too many threads on headers but id like to ask everyone what headers i should get this summer? also, are all long tubes illegal...name some brands and types for me please!
How big is your budget?
Does your county do emmissions testing? If so long tubes may be illegal for you to run. They can be had with emmisions hook ups but require you to move your cat if you want to run one.
Do you plan on lowering your car? IF so that may be another reason to not run long tubes.
If you want to stay safe, go with a set of shorties or mid lenghts. Macs and SLPs seem to be 2 of the more popular brands, AS&M and RKSport the supposed "best."
Long tube wise, Hooker and Jet-Hot are popular. Pacesetters were just released not too long ago and are gaining in popularity. Just remember you also have to buy a Y-pipe when you run long tubes, and that can be an extra $150 or so..
ya my county does emmisions...is it a guarentee that having the long tubes is illegal? is the only reason they are illegal because you dont have a cat? if so i guess ill go with the mid-lengths (unless i cant lower my car with those either) im planning on lowering my car...does that mean i can only go with the shorties or could i go with midlengths.
The catch with the longtubes is that you can run cats (either integrated into the y-pipe or after it) but they will not be in the stock location. In some states it is illegal to move your cats. I doubt the mechanic inspecting your car will notice, but it may be a risk you dont want to take.
Longtubes also tend to hang a little lower than other headers. Our cars are already low, and if you plan on lowering the car with long tubes you may have to end up avoiding speedbumps. Shorties and milengths tend to tuck up tighter.
I noticed your car is a 96 with dual cats. Shorty/midlength headers designed for the dual cat are usually not as efficient at those designed for the single cat cars. A lot of people will suggest you converting to the single cat style exhaust system.
Do a few searches on various brand headers, then see what fits your budget. Its not really a question fo which headers provide the most gain, as much as it is which are best for your application.
My MAC headers are emissions legal. My car runs 12.0 with the A.I.R. and EGR still hooked up.
I run through an Off-Road Pipe in place of my cat while at the track, but both my ORP, and Cat are flanged identically so I can swap them in a matter of minutes.
MAC headers are easy to install, they have great ground clearance, and great spark plug access...Oh Yea, did I mention the 12.0's?...LOL
Frank
Frank
note:
if you convert to the single style you will have the same illegal issues as the longtubes since basically one of the cats will be no more and the remaining one moved back a little bit. so if you are going to be illegal go all out and get the long tubes.
the AS&M headers with the Random Technology dual cat y-pipe looks like a pretty good setup, i'm debating doing that and getting the Random Tech. catback with it, or doing jet-hot longtubes with a mufflex Ypipe and the mufflex 4in. cat back. i am in kansas so i have no emmissions testing here. anyone have any thoughts on which of those setups would work best with the 221/227 cam?
FLP's are nice longtubes also. I've had these on for around 2 years with great results, no problems at all. It is not a cheap kit, but if you are considering the ASM w/random tech pipe, the cost will be about the same. FLP's cat converters have been great too, no problems with those. You do have tight plug access on a few, and the oil cooler has to be removed. These headers fit in without moving the motor. The best thing about them is they sound great.
is desireable, not the single cat configuration. It's better to
run two cats if you have the space. If you are planning on
relocating the cats you might as well upgrade to two 2.5"
since the stock cats are only about 2.25". You should also
avoid the small bullet style cats and go with some with a
larger cross section.
Originally posted by truedualws6
Actually, it's the design of the early single cat headers that
Right now, I put one 3" high flow cat after the Y-pipe on my single cat headers, but it still doesn't flow as good as two stock cats. That's why I'm going to try a bullet muffler with flanges on both ends so that I can bolt that in instead of the cat when I want to. Then there is NO cat to restrict flow.
You will still see a HP gain with the headers and single cat, but it just won't be as much as no cats.
Dan
