Are headers worth it?
Old 12-04-2006, 02:53 PM
  #16
Jlo
Jlo's Avatar
Originally Posted by redrider4
I am wondering if headers are worth it on a 94 lt1. Just wondering if they are worth it for the money, installation, and power. I have been looking at the pacesetter longtubes with their y pipe. I am just courious to see if they are worth it for these cars. Any answers are greatly appreciated! thanks....
Yup!! they are worth it.
Jlo is offline
Old 12-04-2006, 03:41 PM
  #17
Critter's Avatar
YES
summit sells copper gaskets get them too, pacesetter coated longtubes!
Critter is offline
Old 12-04-2006, 04:57 PM
  #18
BassProCamaro97's Avatar
I gained a few mph in the trap. Enough to put me around the 101 mark. however, my car could not hook up for anything so I can not get you a good number as for qrt. mile.
This job really is no fun to do but, just for the fact that I can change my plugs and wires now in probably a third of the time makes the labor well worth it. Call me crazy but I like to work on my 97.
Not to mention you can't beat the way a V8 sounds with long tubes and true dual exhaust.
~Jim~
BassProCamaro97 is offline
Old 12-04-2006, 06:01 PM
  #19
JohnnyPappis's Avatar
Originally Posted by z28rp
u cant just install them in your garage, i tried to do this. the engine has to be taken off the mounts and lifter 5 inches to fit the headers, unless your wiling to do this get someone to do it for you. I have the same thing 94 lt1
uh......no way dude ive installed 3 sets and get the aluminum reusable gaskets from autozone i dont like the place much but those are awsome and you usally hafta have em order them
JohnnyPappis is offline
Old 12-04-2006, 07:50 PM
  #20
redrider4's Avatar
Alright cool, Thanks soo much for all the replies everyone of them helped! So do u really need to tune it after u get them on so it runs good? Also are there any other problems to look for or that could happen with installing longtubes? Well I will probably order the pacesetter longtubes not coated with ther y pipe sometime in the spring when its more reasonable weather to put them on. Also does the longtubes with their y pipe bolt right up to the cat? Thanks again...
redrider4 is offline
Old 12-04-2006, 07:58 PM
  #21
rasputin's Avatar
to the original question...YES! headers are a necessity if you plan on doing anything beyond an air intake down the road! I ran 13.5's with mine and I bet I had a bit more left in it!
Just get an LT4 knock module, it should fix any issues and its simply a good thing to have. Try Jason Cromer, he'll get you a good deal. Do a search for more info on him.
You wires could get burnt like mine, but you should be able to get a nice wire kit that drapes it over the valve covers from summit for not much and then use zip ties accordingly. you should probably upgrade your wires while you are at it to be proactive with your cars maintenance.
There are two styles of y-pipes, off road and catted. Off-road has no cats and usually gives you and extra 5-10rwhp, but will make you fail emissions. So you would have to get another y pipe with cats to pass which will cost more. remember, modding your car is not cheap, easy, or reasonable!
rasputin is offline
Old 12-04-2006, 08:16 PM
  #22
95LT1conv's Avatar
if your ganna get teh pacestters spend the little extra and get them coated. too much work to have them rust out in a few years and have to do it all over again.
95LT1conv is offline
Old 12-04-2006, 08:19 PM
  #23
Moderator
Javier97Z28's Avatar
Headers are a "must do" stepping stone mod to anything else after cold air and catback.
There's no question they are worth it, and yes, they can be installed in your garage.
Javier97Z28 is offline
Old 12-04-2006, 09:05 PM
  #24
redrider4's Avatar
Ok, Well i wasn't planning on doing anything after the headers...Right now i have magnaflow catback and a test pipe, I just rebolt my cat back up when its time for inspection. So if i don't plan on doing anything after headers should i still go ahead and do them anyway?
Old 12-04-2006, 09:09 PM
  #25
Camarocracy's Avatar
Hate to be the party crasher, but I don't think you'll pass PA emissions with longtubes. You'll be running an off-road pipe with no cat.
Camarocracy is offline
Old 12-04-2006, 09:23 PM
  #26
redrider4's Avatar
Not being a party crasher at alll...These are the kinda answers i am looking for. But i thought maybe if i got there headers and y pipe that it would bolt up to the stock cat.
Old 12-04-2006, 09:28 PM
  #27
Z95m6's Avatar
Headers are the only bolt on mod besides a supercharger you'll actually feel a difference with. I didn't notice any gain from a CAI, or from a Catback, or roller rockers. The only mod i noticed a real kick in the pants from was the headers. They're also a must if you ever want to go more than bolt ons. If you get you a good set of headers too it can make changing spark plugs a breeze.
Z95m6 is offline
Old 12-04-2006, 09:45 PM
  #28
razor02097's Avatar
it depens on emission laws where you live but you can get a 3" slip on cat then cut the flange off of the catback and mate it to the slip on cat.
razor02097 is offline
Old 12-05-2006, 08:02 AM
  #29
Moderator
I wasn't going to do anymore than a cold air and catback at some point... look at me now
Old 12-05-2006, 08:58 AM
  #30
2000GTP's Avatar
Yeah, I thought the same thing as well. Then after the headers, the nitrous kit was next to arrive. Now I'm rounding up parts for an LE2 buildup. It never ends.
2000GTP is offline
Quick Reply: Are headers worth it?
