Heat Tube Banjo Bolt Seals/Washers
I went to order the seal/washers that go to the bungee bolts that hold the heat tube on the back of the heads today. When I was ordering them I asked for two. The service guy said "It says it takes 4". I only remember taking 1 off each bungee bolt on my Z28 and years back on my 92 Vette when I rebuilt it. I just wanted to check to see how many I need for both sides. Thanks.
A few years ago, someone posted a Corvette part number for the same seal washer (different application I think) and apparently, it is a lot cheaper than the $6 or whatever GM charges for the LT1 engine seal washer. Maybe someone else will remember what that part number was - Anybody?
07-04-2005 05:00 PM
