Help with 1.6rr
Old 03-18-2008, 12:40 AM
TasTe GOOD's Avatar
Question Help with 1.6rr
Thinking about getting 1.6rr's. My car is all bolt on so far. Any advice in choice of roller rockers with 3/8 studs. Anything else I should replace or do? Do I need stronger valve springs and new push rods? Any help would be awesome. Thanks!
TasTe GOOD is offline
Old 03-18-2008, 06:48 AM
2000GTP's Avatar
I like the Comp products, you'll get different inputs as to brand. Better valve springs are a definite and stronger pushrods are recommended as well. Depending which rocker arms you go with, you may have to notch the valve covers as well.
2000GTP is offline
Old 03-18-2008, 08:57 AM
Stl94LT1's Avatar
My advice would be go with 7/16 rockers (Comp Pro Magnum). Also get a set of chrome moly pushrods (Trickflow), guideplates (Trickflow), and a good set of springs. These upgrades will be a good base for future mods (heads/cam).
Stl94LT1 is offline
Old 03-18-2008, 08:20 PM
TasTe GOOD's Avatar
Awesome, thanks for the info, what kind of springs should I go with, maybe lt4 springs? Not looking for anything fancy, just something to support the 1.6rr's till future cam, heads, etc..
Old 03-19-2008, 07:17 AM
2000GTP's Avatar
LT4s would be all you need for rockers only and they are cheap.
2000GTP is offline
Old 03-19-2008, 01:44 PM
95ltbird's Avatar
stealing the thread for a sec... will 1.7 rr fit under stock valve covers? and will the lt4 springs work with them also?
95ltbird is offline
Old 03-19-2008, 01:51 PM
LSWHO's Avatar
No.
I woudn't try it.
LSWHO is offline
Old 03-19-2008, 01:55 PM
HottestZ28's Avatar
when doing springs can you just do springs only? no shims, retainers, etc
HottestZ28 is offline
Old 03-19-2008, 07:40 PM
max_ta's Avatar
just got done putting mine on, crane gold 1.6 sa.,for center bolt valve covers.Had to change retainers and locks too,on engine and it sucked but it's done
max_ta is offline
Old 03-20-2008, 11:26 AM
HottestZ28's Avatar
do you just buy a LT4 valve spring kit?
Old 03-20-2008, 01:47 PM
ttop1986's Avatar
I was wondering about how to go about ordering lt4 springs and such as well. I know shbox has the part numbers on his website, but how many of each part will I need?
The bold part #'s I absolutely need, and the others are optional.
12495494 - lt4 valve spring set (set of 16)
12495492 - lt4 valve spring retainers (set of 16)
12495503 - lt4 valve locks (set of 32)
10212809 - Shims... Do I need these and how many? (part # for 1 shim)
2x 10212810 - valve seals, intake (set of 4)
2x 12564852 - valve seals, exhaust (set of 5)
ttop1986 is offline
Old 03-20-2008, 08:49 PM
max_ta's Avatar
I put isky springs rated for .560 lift but I was told you could put 1.6rr on stock springs not sure someone else chime in here, I am still on stock cam.I guess I won't have to worry about valve float.
max_ta is offline
Old 03-22-2008, 03:47 PM
TasTe GOOD's Avatar
What is better? Self aligning or none self aligning rockers? What do the non s.a. rockers require?- Extra work, parts, etc.?
Old 03-22-2008, 04:12 PM
96m6lt1's Avatar
NSA rockers are the best route,all you need extra is hardened pushrods,isky adjustable plates.While doing this you should upgrade to 7/16 studs...its almost like free hp compared to the 3/8 studs..
96m6lt1 is offline
Old 03-22-2008, 04:35 PM
2000GTP's Avatar
The SA rockers are the best bet if you just plan on doing the rockers as a standalone mod with no intent of upgrading to a bigger cam down the road.
2000GTP is offline
Quick Reply: Help with 1.6rr
