?help?
?help?
what would cause the car to pop in the intake. could the intake elbow be the problem because it is old and comming apart. what could be the problem. the car runs fine but it just pops when i rev it up. just a first. like at 1000 to 2000 rpms.
Re: ?help?
You might want to add a signature showing the basic info like the year of your car, tranny type and any major mods. A torn inlet elbow screws up the MAF cars pretty badly. But is isn't going to do too much to a speed-density 93, other than fill the cylinders with nice dirty air.
Re: ?help?
Add a "signature"..... then you won't have to keep typing the information on every post.
Before you do anything else, patch or replace the inlet elbow..... you are really screwing up the air/fuel control by letting air bypass the MAF, and you are pouring filthy, hot, unfiltered air into your engine. Fix the elbow, then see how it runs.
