Help!!!!
Help!!!!
I just put in a new radiator, and drove it about 12 miles, and now the fans aren't coming on. It's overheating, and water is erupting out of the radiator. I think it's the thermostat is sticking and the fan relay is bad. Any suggestions? HELP!!!!
The one in the pump is the one used by the PCM for controls for things like the fans. The other temp sensor in the engine on the driver side is for the gage only.
Put the AC on and see if the fan comes on. If so, the relay and wiring is obviously ok. You could also monitor the PCM temp to see if it's reading correctly.
Perhaps you didn't bleed the system correctly?
