help 96z28
Old 10-03-2008 | 10:34 PM
alfieboy's Avatar
help 96z28
I was working on 1996 chevy camaro z28 w lt1 350.. new to the newer (lt1) engines......
What I was doing was removing dampner on crank to replace the front crank seal(leaking).. upon looking noticed we had broken th elower vent tube on th eoptispark... so I took a lil piece of brass tubing(brake-tranny line) and cut a small piece to stick in the opti spark cap hole where it broke an dthe piece which brok eoff to connect the hose.. then re connected th ehose and finished seal install..car starts runs good.. but now th efactory tach stopped working, can you PLEASE HELP me figur ethis out?.. didnt touch anything else.. wiped off the opt with arag..but no other stuff done....would that affect the signal to the tach by fixng the vent>??.. or i sthe opti maybe going bad,still runs perfect..?..Im ne wand lost to lt1..old school.... and I am unsure what went wrong. If you caould help and have no prob with returning the favor to you in some way somehow.
Rick
Old 10-04-2008 | 01:22 AM
mrmint69's Avatar
Should not be related. Something else happened to cause this.
Old 10-04-2008 | 06:30 AM
The tach is driven off pin A13 of the PCM, white wire. If the engine is running, the PCM is getting the RPM data from the Optispark, and the tach should work. Nothing you did should have affected the tach.
Old 10-04-2008 | 10:24 AM
94arcticwhiteM6's Avatar
smack your cluster with your finger. i did plug wires a long time ago and when i started the car i had no tach, i thought i had messed up something but i smacked the cluster and its worked fine ever since.
Old 10-04-2008 | 09:40 PM
alfieboy's Avatar
tach issue
so sticking th emetal tube in th ebroken hole for the vent wouldnt affect anything./.didnt remove any wires or anything.. JUST cannot understand how it be working, try to fix the seal..and now it stops.. or has its own mind.. never ever gave a problem prior to this.....Will try banging dash tomorrow..?...O dunno what else to do..
Old 10-05-2008 | 12:13 AM
alfieboy's Avatar
banged the dash, it worked.,.guess i need a tack...thanx
Old 10-05-2008 | 12:15 AM
alfieboy's Avatar
how can I close thread....???
thnx for answering everyone..
Old 10-05-2008 | 08:02 AM
You don't have to close the thread..... just let it sink to the bottom of the list. Posting the solution was helpful, in case someone else has the same problem and does a "search".
mmf_1013
09-12-2015 08:56 PM
2BLKZ28S
04-07-2009 12:31 PM
joe-96z1le
09-29-2005 12:33 AM
Ripcurl3249
01-10-2005 09:59 PM
ollie-99
08-25-2003 02:53 PM
Quick Reply: help 96z28
